Re: Stuck bolts
live ɘvil /
> Pops Peds Wrote:
> You might take a chisel.and hammer to bump it around enough to loosen
> it....don't use a real sharp.chisel...needs to be a little dull so it
> will hold on the side of the bolt head
> ..get it at an angle to make an indention then at an angle to turn the
> bolt when you hit it...you want to be hitting the side if the head ,not
> the top
Says the junkie on morphine. Pops is a retard.
