Re: NC50 battery not charging
Jack Rutherford /
Many of these batteries ship without acid so you need to add acid to the battery to the proper level and not water. Battery instructions often recommend that you do this over a period of time as the level you fill to can go down after the battery sits for a few hours. Assuming that is the case, my trickle charger and others won't even charge a new battery because it has some built in safety device or related BS that kicks in and won't charge the battery if the voltage is too low. I've had success filling the battery and then going on several 20-30 minute rides to charge the battery.
Or perhaps you can take your battery to a battery's plus and they might be willing to charge it for you overnight. They usually prefer that you buy the item there.
Beyond that, make sure all the wiring under the seat is properly connected and check the rectifier for connectivity as well. Double check the wiring from the stator connections which will be coming out of the frame near the carburetor. (edited)
  NC50 battery not chargingTopic by: Daniel Scott Daniel Scott 07/19/20 06:11PM
  Re: NC50 battery not chargingRe: P D P D 07/19/20 07:11PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/19/20 11:02PM
  Re: NC50 battery not chargingRe: Jack Rutherford Jack Rutherford 07/22/20 12:59PM
  Re: NC50 battery not chargingRe: live ɘvil live ɘvil 07/20/20 06:21PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/22/20 12:40PM
  Re: NC50 battery not chargingRe: live ɘvil live ɘvil 07/22/20 01:50PM
  Re: NC50 battery not chargingRe: Stephen Keller Stephen Keller 07/22/20 02:02PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/25/20 11:10AM
  Re: NC50 battery not chargingRe: P D P D 07/25/20 06:48PM
  Re: NC50 battery not chargingRe: Kurt Van Luven Kurt Van Luven 07/25/20 06:53PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/26/20 12:50AM
  Re: NC50 battery not chargingRe: Kurt Van Luven Kurt Van Luven 07/26/20 02:58AM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/26/20 09:54AM
  Re: NC50 battery not chargingRe: P D P D 07/26/20 10:00AM
  Re: NC50 battery not chargingRe: live ɘvil live ɘvil 07/26/20 01:55PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/26/20 09:56AM
  Re: NC50 battery not chargingRe: Kurt Van Luven Kurt Van Luven 07/26/20 11:46AM
  Re: NC50 battery not chargingRe: Jack Rutherford Jack Rutherford 07/28/20 09:17PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/24/20 11:01PM
  Re: NC50 battery not chargingRe: P D P D 07/25/20 08:07AM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/25/20 11:06AM
  Re: NC50 battery not chargingRe: Kurt Van Luven Kurt Van Luven 07/25/20 11:04AM
  Re: NC50 battery not chargingRe: Kurt Van Luven Kurt Van Luven 07/26/20 03:00AM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/26/20 05:51PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/26/20 06:47PM
  Re: NC50 battery not chargingRe: P D P D 07/27/20 08:22AM
  Re: NC50 battery not chargingRe: live ɘvil live ɘvil 07/27/20 12:11PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/27/20 02:42PM
  Re: NC50 battery not chargingRe: P D P D 07/27/20 04:26PM
  Re: NC50 battery not chargingRe: live ɘvil live ɘvil 07/27/20 07:37PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/29/20 12:30PM
  Re: NC50 battery not chargingRe: Daniel Scott Daniel Scott 07/30/20 11:11AM
