Why is it so hard to pedal start Hobbit?
Steve Parsons /
Got this 1978 Hobbit PA2 running after being in barn since 1082/83. Seems to start and run well....using an electric drill to spin motor over. So I tried to start it using the pedals...damn, could hardly get the pedals moving! There seems to be a lot of drag in the system before the motor...in the rear gearbox? Maybe I'm just to weak and light (130pounds, age 77+). Any known solutions and/or repairs I should look into?
Thanks
Re: Why is it so hard to pedal start Hobbit?
Are you pulling the decomp lever?
^ That should help, but I have never used mine (decomp) in the 22 yrs I have owned the same bike, being light may be your issue. I wish I was still light! :) If the rear pulley is bad you should not break about 18-20 mph when you should see 30-33 mph top speed, especially at your weight. @ 200 I got 31 mph out of mine on the flats.
u can push start it as well instead of pedaling.
Steve Parsons /
The decompression lever helps only slightly. I just can't maintain the pedling long enough and fast enough to engage the starter clutch. Age has taken it's tole the past couple years. Will have to get a friend over to try it out.
Thanks for the replies.
Maybe look into a pull start? Several people on here have made/sell them. Not sure if treatland.tv has them but worth a look.
Steve Parsons /
thanks....will look...Treats no longer has them
Yeah it is s sucky part about hobbits.Bump start is easiest on them maybe.Is your rear pulley opening up properly?I have a problem with my pulley right now,and it makes kicking it over really hard.
Steve Parsons /
The pulley seems to be working right....squeezing the belt together causes the rear pulley to open up. Should the pulley open as you pedal against compression?
Emil Kniemel /
How is your chain? Is it easy to pedal in bicycle mode?
Steve Parsons /
Chain seems fine...pedals easily. It's just me, I think...a couple years ago I wouldn't of had any trouble. I'm at the moment trying to get the electrics hooked up properly (ignition switch, kill switch...using a jumper wire at the moment) and once that done, may disassemble the starter clutch to see if anything wrong there.
Thanks
I made an adapter once that connected the pedal shaft to a drill. Then I could bed in the new starter clutch shoes that weren't catching.
Is there a one way bearing kit for the hobbit? That might help.
Aaron Ward /
Little bird legs?
Barry (Bob) Brown /
Emil Kniemel /
There is a one-way. Also he 's over 75 years old and only weighs 130. The one-way would help but i suspect he would get a lot of rear wheel dragging before being able to build momentum to start it. I have this problem but I'm half his age.
