Re: Just a quick question about a needle bearing
P D /
> Martin Fotak Wrote:
> If i manage to get bearing that can fit 12mm connecting pin and also not
> be too big for a hole where it sits ill do that
> Thanks!
You're likely gonna be pushing it to it's limit .
I doubt you'll find a bearing for that conversion , so just do the bushing and wait for things to seize . ;)
If you weren't prone to pushing , I'd think about honing the small rod end to fit the less than 2mm bigger bearing , but ...
