My front sprocket moves left to right about a 1/2 (sach engine ) everything works so I was thinking on removing the sprocket and put a spacer in. Any thoughts ?
Don't space it tight. 2 thinner spacers would be better than one. Grease them up!
So that should work ? Was thinking maybe nylon ?
I'm pretty sure nylon would just shred after awhile.
What about a thin spacer on each side with a bearing in the middle ? I could rig that up ? So take off the sprocket put a spacer then bearing then spacer or am I over thinking it ?
sounds like you need to replace your output bearing, or like your front sprocket's taper is shot and you need a new sprocket
