Any final advice on how to get this thing fired up before I buy a new carb ?
I blasted it with carb cleaner, compressed air. Ultra sonic cleaned it 3 times. New gasket kit from treatland. Set the fuel adjustment screw so that the needle is all the way down.
New spark plug
I have spark
Points set correctly
New fuel line / filter
New gas
New oil
This bike will NOT run ! It was fine I got pulled over by the cops and after I sat there for a while talking to them with it running it died about 3 miles later. I took the carb apart and it was full of red rtv sealant. I cleaned it with carb cleaner really quick. Put it back together. It fired right up. I drove it for about ten mins and it died again. Ever since then it would take forever to start and would barley idle. You could rev it up but then it would die if you let it go back down. This was last year.
So I just did all of the above hoping doing it right would do the trick and it’s just not starting I tried for a half hour choking it. I tried taking off the air filter and putting my hand over the hole. It wouldn’t even putt for a second. Super frustrating. Any advice would be greatly appreciated.
