Moby 50V Motor Mount Bushing Removal
Pushrod Fifty /
I made the DIY puller described in the wiki, and even better with a .25" thick aluminum washer that I cut to size that is just a little smaller than the bushing, with .25" center hole for the threaded rod. I have a 1/2" socket that fits perfectly to the outside frame flange with enough clearance for the bushing to go into. I cant get the bushing to budge. I put some light oil around the bushing and pulled from the inside outward. Is there a better way?
Re: Moby 50V Motor Mount Bushing Removal
Pushrod Fifty /
I got it to work, greasing the threads was the trick.
Those mounts are a PITA...but ya gotta do what ya gotta do...
