Re: Honda Camino PA50 Carb / Idling Issues
W D /
Thanks for the reply. Will keep trying with the cleaning!! Any other hints or tips?
Any reason why idle mixture screw has no effect? Is it due to the idle / tip in circuit issue above?
I can see the 2 tiny holes that sit next to each other in the Venturi / throat aperture where the throttle valve is. Are these the ones that need thorough cleaning?
Thanks
  Honda Camino PA50 Carb / Idling IssuesTopic by: W D W D 07/10/20 07:53AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Aaron Blair Aaron Blair 07/10/20 08:36AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 09:16AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 10:13AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Stephen Keller Stephen Keller 07/10/20 03:19PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 03:39PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 04:54PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 05:05PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 05:34PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Stephen Keller Stephen Keller 07/10/20 09:08PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/11/20 05:37AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: pat splat pat splat 07/10/20 10:24AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 11:07AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 11:33AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: pat splat pat splat 07/10/20 01:51PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 06:21PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 06:57PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 07:05PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 07:44PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Aaron Blair Aaron Blair 07/11/20 07:25AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/11/20 11:13AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/13/20 06:20AM
