Honda Camino PA50 Carb / Idling Issues
W D /
Hi had a read of the wiki for the Pa50 carb and have followed all the cleaning instructions and info on there but still can’t to get it to idle without it dying.
From what I’ve read it will be an issue with the tip in / idle circuit.
Thinking that it will need to be ultrasonically cleaned to get rid of the debris in the carb. Anyone had luck doing this?
Also adjusting the air screw doesn’t appear to have an impact when I screw it in or out. Is it subtle or should there be a noticeable change?
Any help would be appreciated.
Thanks
  Honda Camino PA50 Carb / Idling IssuesTopic by: W D W D 07/10/20 07:53AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Aaron Blair Aaron Blair 07/10/20 08:36AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 09:16AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 10:13AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Stephen Keller Stephen Keller 07/10/20 03:19PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 03:39PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 04:54PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 05:05PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 05:34PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Stephen Keller Stephen Keller 07/10/20 09:08PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/11/20 05:37AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: pat splat pat splat 07/10/20 10:24AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 11:07AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 11:33AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: pat splat pat splat 07/10/20 01:51PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 06:21PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 06:57PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/10/20 07:05PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: P D P D 07/10/20 07:44PM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: Aaron Blair Aaron Blair 07/11/20 07:25AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/11/20 11:13AM
  Re: Honda Camino PA50 Carb / Idling IssuesRe: W D W D 07/13/20 06:20AM
