Re: 1978 Batavus Regency HS50 No Power / Smells Hot
Mark Anderson /
I think I am going to pull the trigger and upgrade the carb. Me reeds look okay (stock). I inspected them and there are no light leaks.
Did you keep the reed riser (spacer block) with the new intake? What size jet are you running? Also, I see you selected the one WITH the choke cable. I was thinking of shit canning the choke cable and going with the lever style and getting rid of the extra cable. Any thoughts??? Is the choke cable plug and play with the old Encarwi cable. I have the thumb lever style choke on the handlebars.
Have you ever had to mess with your timing or points?
