Choke/Starter Cable for Yamaha QT50 is discontinued, what next?
I've recently been restoring a 1984 Yamaha QT50, which overall has been going pretty smoothly, although I've run into one major snag. The choke/starter cable on it is froze up and missing the tip that goes into th carb. I've looked all over ebay, amazon, and even emailed Treatland.tv (they told me to ask around here) and I can't find the right cable anywhere. Theres one on amazon, but its over $40, and in the reviews, it says its still not the correct cable. Does anyone know of a suitable substitute cable I could use, or a way to convert the carb from a manual choke to an automatic (or maybe convert it so theres a choke rod on the top of the carb rather than using a cable)?
Re: Choke/Starter Cable for Yamaha QT50 is discontinued, what next?
What does the tip look like? Pics?
That's a pretty simple chock set up .
Take a look at bicycle cables available from Walmart . 10 bucks for a pack .
You might have to solder your own end on the cable , but that's all of a couple minutes time .
Or reshape an existing cable end ...
Always more than one way around a bush . ;)
You might check a mid 80s Suzuki FA 50 choke cable . Seems like the same set up .
https://www.partspitstop.com/oemparts/a/suz/50d3eb1cf8700230d8b4aed2/handlebar
The FA cable has a metal bend . but ...
CABLE, STARTAR 58410-02200 (edited)
This is the best picture I could find of one. On the small end, the metal cylinder is sitting on it's long side where it attaches to the wire.
Maybe time to make something work .
Fine a cable that's close and 'adjust' it . ;)
Actually that cable looks very close, if not identical to the one I need. I ended up ordering it. Even if it's not perfect I should still be able to make it work. Thanks for your help!
Keep us posted on your progress , please . ;)
Just FYI the cable that pdcomm linked to above came in last week and ended up working with just a minor modification (the handle bar end of the cable was too small, so I got a crimp on connector from my electrical supplies, cut it to the right length, and crimped it around the existing cable tip.
Beach Club Nick /
Nice. I think a huge part of being into mopeds is learning to make your own cables
Good . Making something work is what it takes . ;)
Could you show me where your choke cable it running into your carb? Both holes on top of my carb are taken up my throttle cables. One for the oil, one for gas
> oil, one for gas
Going to need a pic of that.
If it's the correct OEM carb. and cable, it's not set up right. Throttle cable runs from twist grip to a splitter where one cable goes to the the oil injector and one to the carb.
Andrew Snowberger /
You still have the original cable? Send it to MotionPro they can custom make cables, they will send back your original cable and the new one they made. Worked for my old CBR. Think theyre still in the bay area in California
