1977 Puch Maxi Engine Oil?
I see there is transmission oil but I don't see anything in the manual or drain/fill plugs that would denote a dedicated engine oil system. Is the engine cooled by the transmission oil? I don't want to screw this thing up. Thanks
Re: 1977 Puch Maxi Engine Oil?
The engine oil (2 stroke oil) is mixed in the gas at a 40:1 gas/oil mix.
Research how a two stroke engine works to understand more.
> thing up. Thanks
Look on the bottom of the engine. Trans oil is Type F ATF
Probably Fred /
> Is
> > thing up. Thanks
If do you want better protection and your clutch is stock material then run synthetic motor oil 0 to 5 w20-30 weight it’s about 10 times better than junk type F tranny fluid,
Even regular Dino motor oil is better then type f in a puch tranny
Craig Jakus /
Thanks.
Craig Jakus /
Thx. So no dedicated engine oil.
Craig Jakus /
Really. Good to know.
I tried 0-10w oil and I burned a clutch. try one if you don't like it run the other.
Yes, it is the 2stroke oil you mix in the gas. You must have this as it is your engine's lubrication.
There is no engine oil reservoir. The only engine oil is the two stroke oil you mix in the gas before dumping it in the tank.
