Garelli clutch
pat stevens /
rebuilding the engine and putting it back together, have wondered about the clutch. One side is a bit glazed it is cork. I have read on the forum that it can be fliped, or is better to buy a new one? Treat has one that is non cork. Also any idea in the rubber grommets.. I have 1 new one goofed the order.. is it better to use rivet or get the other 3? I can't really decide which way is up or down on the new one. Any and all help is appreciated. Stuck at this moment.. have painted and redone everything to this point. Would like to finish but do it right.
Re: Garelli clutch
its a pain those little rubbers but I've managed to reuse them by slowly pinching the plates together and grabbin, lifting, picking, cursing those triangle little nipples back into place.
Re: Garelli clutch
That is a starter clutch. It utilizes one side at a time. Flip it over if you're concerned. The rubber clutch that propels the bike is completely seperate. Always buy extra nipples cause you're gonna fuck up one or two.
Re: Garelli clutch
> everything to this point. Would like to finish but do it right.clutch
Just get some nipples. And a clutch. I am sure the one in the bike should be replaced along with the nipples. Just remember to use 30w Non detergent oil in the tranny when you get it back together.
Re: Garelli clutch
> Jay Rivett Wrote:
> about
> 3?
> redone
Flipped when worn out, not replaced. Any replacement will most likely not be of the same quality as oem.
Re: Garelli clutch
The starter clutch is pictured. The rubber clutch that drives the moped is what I am referring to. Yes flip the starter clutch, but you have to replace the rubber one. It gets bloated and flipping would do nothing for it.
Re: Garelli clutch
> for it.
Really? 2+2=4
Re: Garelli clutch
Sometimes it actually is 3....
Re: Garelli clutch
In the new math , wouldn't 2 cover 2 and end up only 2 ? LOL
Re: Garelli clutch
I know ND 30w oil goes in the clutch side case. Do I use the same oil in the middle section or trany fluid? Or maybe something else in the middle.
(edited)
