Re: My e50 with a za50 stator magnito
Johnnie Walner /
Yea you were dead on it ran like crap and it wasn't lapped correct causing it to jump timing i switched over to this setup similar to the original picture posted and runs pretty well. But now I can't get the headlight to work on this one i think the coil doesn't supply enought wats to run a headlight bulb and running and tail light all at once. Whe I turn the headlights on the back running light cuts off. When I turn it back on lback lights work again. The za 50 flywheel was causing engine knocking noises and wouldn't run for more that 3 minutes without jumping time but this one ive put several hundred miles on it in the day time. I really need to fix the headlight to work. Can I take the light coil outta my original flywheel that came with the bike and put it on the one below in the image? Sorry for the late response. And I appreciate all the help i did away with the za 50 fluwheel setup maybe I can use the light coil off the za 50 for lights or the old wine that came with the bike? Anyway thanks everyone!
