Re: My e50 with a za50 stator magnito
Dirty30 Dillon /
Even though they run reverse direction, they are not 180* out, they are close enough where you could probably get it to fire, if run very poorly.
If you are insistent on running the ZA flywheel, you'll need to lap the weight to the crank and run keyless, at which point you might as well just buy a real E50 flywheel and not have to worry about setting it freehand every time you need to pull it.
