Re: PA50 carb bowl drain direction...
Steve Parsons /
Okay....found the reason the carb bowl drainvalve should be on the right side of the carb when installed on the engine ("right side"= with you sitting on bike, going forward)...the drain screw can be accessed with a screw driver thru a hole behind the pedal sprocket! It can't if assembled on left side. I was especially pleased to find this hole, as the dummy who assembled the carb forgot to tighten the drain screw!
