She ran two weeks ago I tried to start her up, won't start. Getting fuel, the plug looks good to me anyway. I probably should replace it. How should I adjust the screw on the carb? It's currently a half turn out. After that I'm stumped.
taillight has to work, like a safety switch. Wiring or bulb, I thinks its wiring. WIKI section has your wiring diagram.
is the plug wet or dry?
It's funny you mention the taillight. Whenever I applied the brake lever the engine would cut out. I removed the bulb and pull the lever engine stays running. I've been running it with the bulb out. It's been starting and running well. It just now all of a sudden won't start. I need to check the wiring and add a /run/kill switch. I've been using the choke lever near the throttle grip to kill the engine.
The plug is wet. I put a new plug in and still won't start. Acts like it wants to start though. I pulled the air filter, it's oily and dirty. I'm going to get a new one and clean up that carb. I did notice gas on the floor that has leaked from the carb since it last ran. I'll have to give it a good cleaning. New plug ,air filter and clean carb. Hopefully she'll run after that.
Do you have spark? Do you have a magneto puller yet?
If the light it killing the bike....disconnect (let go of the brake) . Unplug those wires for a min
I got no spark. Does this just happen. It ran three weeks ago.
for the 2nd time its your wiring. Some wires are wrong or grounded out.
it happens to everyone that is on here, annoying. there are some grounds on the frame, clean those up when u clean all the other stuff.
Bet ya need ignition bud. Buy a puller. Buy treats cdi.
