What fuel should I use in my Hobbit? It will not start with the 25:1 mix and 78 octane pump gas.
I'm running 50:1
Have you cleaned the carb? Hobbit carbs are finicky. Have you checked for spark?
Should start fine with what you said. Sound like you have a bigger problem
I do 32:1, but did run 25:1 for years....not needed. You have another issue somewhere.
