Hi Y'all I just bought my first moped (79 Colombia with a Sachs 505 1A) and I'm trying to get it up and running! The engine runs and idles fine the problem is that when you open the throttle you get little to no power it even struggles to push you on a flat surface. I talked with some people and they suggested starting with the Carburetor (Bing 85/12/101). I pulled it apart and started cleaning it, but the float pin is stuck and I think the choke slide is missing? I'm thinking about just buying a new one and just maintaining it rather than trying to fix it as my friend said the Bing's were not the most reliable in the first place. Do you guys have any recommendations on what to get and will fit on my bike? If it makes a difference I'm thinking about eventually getting a piston kit for it once I get more comfortable working on the engine. the other issue I have been having is with the front brake assembly. When you apply pressure to the brakes the whole thing rotates with the wheel and locks in a position where the arm can't move. I'm having trouble finding pictures of what it is supposed to look like and have yet to open it up. Is it supposed to attach to the forks in some capacity to stop it from spinning or is it likely an internal mechanism is busted? Thanks in advance! ~Kaylee
