Re: The mystery of the revival brake caliper
Born to be WillD /
is this just a facotr of the side to side play? or wheel spacing?
On one hand I could see this being an issue if you bungled your wheel spacers
on the other, your caliper should have some side to side float. this allows the fixed side to be perssed on on side while the other side clamps against it tight. maybe you just need to slide the caliper over on the pins?
