Re: Power issues on any sort of incline
P D /
> aidan f Wrote:
> Okay so i should use brake cleaner! Spraying on all connection points of
> engine? Looking for bubbling/air escaping?
With the motor idling , any leak will cause the motor RPM to noticeably change when sprayed with brake cleaner . Use the little directional tube so you can pin point an area at a time , rather than just bombing the whole motor .
RPM change depends on whether the brake cleaner is flammable ( up or faster ) or not ( down or slower ) .
