Re: Power issues on any sort of incline
Nick Haber /
> aidan f Wrote:
> How do i go about finding the air leak?/ If it is running lean? can i
> add more oil to the mix?
No. You need to spray starter fluid around areas that air could be sucked in while the bike is running. Where the cylinder meets the head, cylinder meets the cases, intake meets the cylinder, carb meets the intake
