Jawa x30, very weak spark
Hi there! Recently got this 1981 jawa x30 (207? 210? Something) for pretty cheap.
Freed up the motor and discovered that it has pretty weak spark (you can see it but its razor thin, and you have to spin up the motor pretty fast to get anything)
And knowing jawas, it has a very complicated ignition, and im not sure where to start, changed the plug, same thing. Guessing it's the coil or the thryster. As the alternator works for the headlights (this is the one with the black 4 wire box and the silver cylinder coil)
Any input on where to get parts as well? Only thing on treatland is tires.
Thanks again!
Re: Jawa x30, very weak spark
mark voznyuk /
Heres a better picture of the ignition system, the coils do have surface rust on them, but the headlight works just fine, so im ruling out the alternator as the main problem (edited)
Pushrod Fifty /
I would start by cleaning every electrical connection and making sure they make firm contact, clean that rusty mess with electrical contact spray. Replace the plug wire and cap.
mark voznyuk /
Well, also, i tested the thyistor and the coil today.
160ohms for the thystier between the 1 and l
And 1 ohm for the coil, seems to be within spec
Guessing its going to be a bad connection somewhere
It's always the thyristor. Trust me, build one or buy one. Just do it.
mark voznyuk /
im hoping to build one in the future, but i replaced the coil wire and cleaned the grounds back up, were back in business!!
clean spark, now to address the second issue, 45psi of compression....
The capacitor component of the thyristors like most don't age well. If it works, my experience has been you get a miss at speed. Hopefully your low compression is simply stuck rings. Good luck, make it go!
mark voznyuk /
thank you
im hoping to get it running and just to ride around for fun.
im guessing the rings haven't moved in 10 or so years!
woundering if the compression release has had it
Guess you'll find that out when you pull the top end .
Then , lap the decompression valve into the seat , so it won't be a problem .
this page has some details on testing the thyristor:
https://www.mopedarmy.com/forums/read.php?6,1834014,1834512,flat=1#msg-1834512
and a great verview PDF here: http://www.jawamoped.com/JawaMoped_Electrics_-_ignition.pdf - if nothing else read this one.
and common issues here: https://www.mopedarmy.com/wiki/Jawa_ignition_testing
the DIY instructions to build one are here:
https://www.mopedarmy.com/wiki/Jawa_Thyristor
I have done that twice and it goes from a weak little zap to fucking inch long lightning bolts.
Glad it works but theyre notoriously problematic and I still support Franks suggestion of replacing it when you can. Do read that PDF if nothing else.
mark voznyuk /
> else read this one.
> nothing else.
yup, anyone know the specs on what thyristor to get? as i clicked the link but nothing, as id like to know before the original box kicks the dust.
and the bottom ring had a hairline crack and broke in my hands, ordered new rings off treatland, hopefully it should run!
hone that cylinder when you put new rings in
check the end gap
wire wheel that rusty ignition rotor too.
its a 207 engine.
reliable as a stone except for the ignition
buy an extra thyrister as a spare
red-yellow-white-blue.....wire sequence
i had a maroon 207 and ran it hard all summer long
it would only go 29mph but i loved it
Combloc styling
mark voznyuk /
Just like Kyle #1
IM BAACK!
So, got the rings in and it puttered puttered ran then died (assuming the thysistor box last hurah!)
Now.
I would like to build the diy one, can someone link me the 3 pin thysistor they used in the picture? As the link isnt leading to anything and im not familiar with thysistors.
I'd like to bump the last post by Mark. Come on, someone out there has to have more info on building a thyristor since the Wiki images have disappeared...
mark voznyuk /
here are some images I found on it, seems straight forward enough (i was lazy and order a new one, wish i never sold that bike)
Wiki images should be back once the wiki update is done; Simon's working on it.
The Jawa ignition is no more complicated than any other CDI. I personally think it's much simpler than the typical CDI, as the magical black box is a super simple, well understood circuit.
A thyristor is a readily available part often used in power electronics, typically constructed in either a PNPN stack or as a cross-coupled NPN and PNP BJTs. Think of it like a transistor that latches on when triggered.
It looks like the thyristor used in the circuit on the moped wiki is an On Semiconductor MCR106-6G; they linked to Newark, who doesn't appear to sell them anymore (always use the manufacturer's part number, not a distributor catalog number, folks!). Should run you about $0.60 from digikey or mouser. (edited)
The Jawa I'm working on (sold as no spark) had a bad spark plug boot. The thyristor tests OK, we'll see if it works.
Thanks, man!
No problem. I'm not certain that this is the best possible choice, but it has worked for other folks so it's certainly worth trying it out. Looks like a pretty robust little guy.
Terry Collins /
When trying to start a Jawa 207 (was working fine prier ). It appears as thought the clutch is not engaging the engine to start. On occasion (I'm using drill starting ) it does seem to engage for a brief moment. The clutch side will turn maybe a quarter of a full turn and that's it. I try (very hard) to get more engagement, on both, the clutch and ignition but it's rather a sloop feeling. Also, I not sure if I read, that the engine stop switch should be used when starting up. That makes no sense to me, but hey, it's a Moped. Thanks a ton for any ideas offered.
