Re: Spark issue that is driving me nut
Richard Eberline /
I responded to this problem before. If you have a OHM meter check your external HT Coil. A Bosch HT Coil has a 1, 15 and 4 on the business side. OHM meter leads at the (200 scale) 1 and 15, you need 1.8 to 2.0 OHMS. Then 20k scale to 1 and 4 should get 5,600 to 6,000 ohms. Screw the ignition wire into 4 and retest. Same #,s good. Test the cap. I use a zero OHM, others are 1k, 5k and 10k. Since every other item is new, wire the the moped with a horn bypass diagram. report back
  Spark issue that is driving me nutTopic by: Jeff Parr Jeff Parr 06/20/20 08:43PM
  Re: Spark issue that is driving me nutRe: pat splat pat splat 06/20/20 09:03PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/20/20 09:19PM
  Re: Spark issue that is driving me nutRe: P D P D 06/20/20 10:09PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/20/20 11:13PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/21/20 12:19PM
  Re: Spark issue that is driving me nutRe: cheetahchrome . cheetahchrome . 06/21/20 12:38PM
  Re: Spark issue that is driving me nutRe: Richard Eberline Richard Eberline 06/21/20 03:00PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/21/20 06:32PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/22/20 11:27AM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/22/20 02:21PM
  Re: Spark issue that is driving me nutRe: cheetahchrome . cheetahchrome . 06/22/20 02:47PM
  Re: Spark issue that is driving me nutRe: Richard Eberline Richard Eberline 06/22/20 09:09PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/22/20 09:44PM
  Re: Spark issue that is driving me nutRe: P D P D 06/23/20 08:59AM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/23/20 03:40PM
  Re: Spark issue that is driving me nutRe: P D P D 06/23/20 04:19PM
  Re: Spark issue that is driving me nutRe: Richard Eberline Richard Eberline 06/23/20 08:46PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/23/20 10:07PM
  Re: Spark issue that is driving me nutRe: Pushrod Fifty Pushrod Fifty 06/25/20 05:45AM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/27/20 09:22PM
  Re: Spark issue that is driving me nutRe: P D P D 06/27/20 09:56PM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/27/20 10:57PM
  Re: Spark issue that is driving me nutRe: P D P D 06/28/20 07:22AM
  Re: Spark issue that is driving me nutRe: Aaron Blair Aaron Blair 06/28/20 08:45AM
  Re: Spark issue that is driving me nutRe: P D P D 06/28/20 09:09AM
  Re: Spark issue that is driving me nutRe: Jeff Parr Jeff Parr 06/28/20 12:31PM
  Re: Spark issue that is driving me nutRe: cheetahchrome . cheetahchrome . 06/28/20 03:05PM
