Fuel in the exhaust
Gabor Levente /
Hello everyone. When I crank the engine over to start it no fuel is getting to the spark plug. Instead it goes out on the exhaust pipe. The cylinder piston and rings are new. Also the gaskets are new. Compression is good. Any idea if this is normal or can anybody tell me what the problem could be?
Bike; 1983 Puch Maxi E50 engine (edited)
Re: Fuel in the exhaust
You left the petcock open for a period of time and the cases flooded?
Gabor Levente /
No. I always close it. When i open the petcock i see the fuel going trough the fuel line
Inside the exhaust or on the exterior??? (edited)
Sounds like your float needle is leaking by
Pushrod Fifty /
If its really hard to pedal at first then you know its the needle and or petcock leaking.
Gabor Levente /
Inside
Beach Club Nick /
If fuel is always flowing when the petcock's on your float is either stuck or nonexistent and your motor is flooding.
Michael Branscombe /
2nd for float needle leaking - clean carb, replace float needle
You might have to replace the needle as michael but first look for trash keeping it from closing off
Gabor Levente /
Found it. As I changed the piston and cylinder they were a bit different from the original and the piston didnt went out enough to open the transfer ports.
