Puch Maxi Electrics?
Daniel San Giuliano /
So Im planning to replace my bad points on my 76 maxi, i currently had a solder condensor and I dont know the points since I cant see them yet but if i bought a screw type condensor and wired points would it still work on my maxi?
Re: Puch Maxi Electrics?
The screw on style condensers are crap. Get yourself a cheap soldering iron and some solder from Walmart and solder the wire to a conventional style condenser.
> style condenser.
This. And I only recommend genuine Bosch points and condenser for your Puch.
> Puch.
And , your old Ford or Chevy or John Deere or ...
Bosch is best . ;)
Yes i have been trying to find some bosch points but nobody seems to have them in stock or at all, i have a good solder set up already but where can i buy the good points?
Treats sells them
treatland.tv
so if im doing a solder set up would i get the points with or without wire, obviously the solder style condensor
Grab the one with the wire. Or you will need to re-use the old one you have. They have a special hook on one end to go into the points mech.
Personally I have not had issues with the screw top condenser from treats. And there are ways of running an external condenser by running your points wire up out of the stator.
Kevin Bishop /
VW condenser from 60’s 5$
Bosch VW condenser from 60’s = Best . ;)
