Got an early 60s puch moped with a manual gearbox. Starts right up after a little tlc. My issue is first gear wont engage unless you hold and put a little more tension on the handle bar shifter. It’s not enough to just pull the clutch and shift.
Second gear works great! Does this sound like a problem inside the transmission or just a cable adjustment? Thanks in advance!
