Re: Motobecane 50V AV7 Clutch Problems!
Rebel Moby /
After you drive and stake the rivets then you need to grind them flush to the friction surface of the clutch cover.
> Jaden Stone Wrote:
> While I totally did this before, I have tried preassembling it a few
> times (cleaning everything, checking thicknesses/order) and the second
> clip will not engage.
> On a separate note, how to I replace the drive clutch arms/pads. They
> come with rivets, but I there is no hole for them to go through on the
> inner bell because the starter clutch needs to ride somewhere.
