Re: Motobecane 50V AV7 Clutch Problems!
Rebel Moby /
If you are putting the variator onto the shaft then loading the components it will always be a chore. Assemble the guts into the variator, it will slide on and lock into place after.
> Jaden Stone Wrote:
> The problem is that second truarc won't fit under it's retention lip
> with all 3 shims. It worked before I rebuilt the engine, I am
> dumbfounded as to how it won't go back together now.
