Re: Motobecane 50V AV7 Clutch Problems!
Rebel Moby /
If you removed a thicker shim that should be between the two truarcs.
Assemble the cartridge, shim, int truarc, shims (thickness here is what adjusts runout), ext truarc in that order into the variator housing and slip on the variator to the drive shaft until you hear/feel CLICK of the int truarc finding its groove. Then check that there is not excessive runout.
Then introduce the drive portion of the clutch assembly (cover and PTO shaft).
