Re: Motobecane 50V AV7 Clutch Problems!
pat splat /
theres something cutting up your variator on the inside, did u do that? metal shaving all over.
Once the variator clips/shims are on you can spin it to double check that nothing is grinding before putting clutch on. Also belt alignment front to back pulley is important.
