Re: Bianchi Eagle - 1979?
Michael Branscombe /
rigged a brake cable … rode this around for a good 2 hours today, just heating up the motor and slowly running it harder to break in the top end.
it is hard to start .. does not idle .. and seems to flood out if I load the motor too much -- by too much I mean, me at 280 lbs trying to go up a hill - eventually it will die out - and then miss and either slowly lose power or clear up and run fine again.
when I've had it running, seems to go pretty good, buzzed around rides good … not sure how to adjust clutch, seems to always want to go even when disengaged, but using the pedals as a kick start it will slip if you're not carful so - maybe I just don't know how to use it, maybe it needs an adjustment, maybe it needs a repair … maybe it will break in again after 30 years of sitting. have standard 30 weight oil in the transmission.
running gas at about 25:1 for break in .. might contribute to it wanting to flood out .. but, it could also be electrical, still uncertain on it. did try running an external condenser, but it seemed to run the same so disconnected it.
and I am running a 40 year old snowmobile coil for a rotax motor, so - not sure that is ideal, but it seems to work.
all in all - pretty neat to get the thing running again … tires were good enough to get this far, but can see they are splitting and could be dangerous .. so, need to find some new ones.
  Bianchi Eagle - 1979?Topic by: Michael Branscombe Michael Branscombe 05/20/20 08:57PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/21/20 09:58PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:55AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 01:35AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:40PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 04:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:15PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 06:17PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:49PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 10:45PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:19PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:46PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/23/20 12:58AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/24/20 02:25PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 03:38PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 08:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/26/20 06:59PM
  Re: Bianchi Eagle - 1979?Re: Rob P Rob P 05/27/20 05:23AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/27/20 09:35PM
  Re: Bianchi Eagle - 1979?Re: Satan 666 Satan 666 05/28/20 06:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/28/20 10:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/31/20 10:22PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/02/20 03:29PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/07/20 01:41AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/07/20 11:01AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 09:54AM
  Re: Bianchi Eagle - 1979?Re: pat splat pat splat 06/08/20 10:24AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 12:47PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/08/20 10:40AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 02:31PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 07:29PM
  Re: Bianchi Eagle - 1979?Re: Jeremy Homser Jeremy Homser 06/14/20 07:37PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 08:58PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/14/20 09:41PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:30PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/14/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 01:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:33PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/15/20 04:54PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/18/20 09:36PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/18/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:23PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:27PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/22/20 12:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 03:27AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 09:13PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 07/09/20 11:00PM
