got new piston, honed cylinder and cleaned things up and installed.
installed fan housing
installed carb
installed exhaust
installed fuel tank and connected to carb
rig electric to run with on/off switch but, bypassed brake switches grounding to frame
started motor, was kind of a hassle - did not want to start, wasn't sure what to do with adjusting needle - started and stalled a couple times, pretty sure I flooded it …
finally got started, ran it for 5 minutes until motor was good and hot - left it for a few hours.
started it again, much easier this time, got motor hot again, left it
clutch seems to spin back wheel all the time, it also seems to slip if I kick the pedal real hard trying to start it … not sure if that is an issue, or if I just need to adjust cables etc.
next to rig up brake switches, and lights … think my brake cables might get here mid week, so I can give it a quick spin …
