Re: Bianchi Eagle - 1979?
Trent Anderson /
> Half tempted to just clean up the
> piston and rings and put them back and > compression test the thing.
I've done that in at least 2 motors. If the rings aren't horrible and have some "spring" left to them, get the rings and piston cleaned up and do a little bit of sanding in the cylinder to clean up some rust there, reassemble, and give it a go.
A motorcycle mechanic felt that the action of the rings might clean up the cylinder as well. I'm not sure I would go riding the bike, but at least you can give things a listen and see if it sounds like something horrific is wrong with the motor.
In all reality, though, if the motor took a month to free up, I would worry about bearings and seals. I would plan on a rebuild if I were you.
  Bianchi Eagle - 1979?Topic by: Michael Branscombe Michael Branscombe 05/20/20 08:57PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/21/20 09:58PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:55AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 01:35AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:40PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 04:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:15PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 06:17PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:49PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 10:45PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:19PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:46PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/23/20 12:58AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/24/20 02:25PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 03:38PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 08:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/26/20 06:59PM
  Re: Bianchi Eagle - 1979?Re: Rob P Rob P 05/27/20 05:23AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/27/20 09:35PM
  Re: Bianchi Eagle - 1979?Re: Satan 666 Satan 666 05/28/20 06:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/28/20 10:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/31/20 10:22PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/02/20 03:29PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/07/20 01:41AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/07/20 11:01AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 09:54AM
  Re: Bianchi Eagle - 1979?Re: pat splat pat splat 06/08/20 10:24AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 12:47PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/08/20 10:40AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 02:31PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 07:29PM
  Re: Bianchi Eagle - 1979?Re: Jeremy Homser Jeremy Homser 06/14/20 07:37PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 08:58PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/14/20 09:41PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:30PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/14/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 01:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:33PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/15/20 04:54PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/18/20 09:36PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/18/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:23PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:27PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/22/20 12:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 03:27AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 09:13PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 07/09/20 11:00PM
