Re: Bianchi Eagle - 1979?
Michael Branscombe /
the bottom end is free and seems good. no vertical play in the rod or anything out of the ordinary. when I had the head off, the cylinder would go up and down and I could rotate and check out the bottom end a little bit, and from what I can tell, seems good.
I have tried some knocking on the piston with some wood and a hammer, and no movement at all. Unsure if the piston is just stuck from sitting or if it was seized up before it was put away. I don't see anything that looks bad about the cylinder or piston, although some light vertical scuffing does show on the cylinder wall, from where I can see the piston through the exhaust port, seems good.
In an effort to not break anything, I'm just sitting it with MMO in the cylinder and exhaust port, and then heating it up good a couple times a day, and working the crank from the flywheel nut to 20ish foot pounds. I figure I'll do this for a few to several weeks, and try to use time, heat, and soaking to free it up.
If it was seized will it eventually come free or will I have to pound it out with force? would like to avoid damage to rod and crank if possible.
  Bianchi Eagle - 1979?Topic by: Michael Branscombe Michael Branscombe 05/20/20 08:57PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/21/20 09:58PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:55AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 01:35AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:40PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 04:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:15PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 06:17PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:49PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 10:45PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:19PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:46PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/23/20 12:58AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/24/20 02:25PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 03:38PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 08:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/26/20 06:59PM
  Re: Bianchi Eagle - 1979?Re: Rob P Rob P 05/27/20 05:23AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/27/20 09:35PM
  Re: Bianchi Eagle - 1979?Re: Satan 666 Satan 666 05/28/20 06:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/28/20 10:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/31/20 10:22PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/02/20 03:29PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/07/20 01:41AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/07/20 11:01AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 09:54AM
  Re: Bianchi Eagle - 1979?Re: pat splat pat splat 06/08/20 10:24AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 12:47PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/08/20 10:40AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 02:31PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 07:29PM
  Re: Bianchi Eagle - 1979?Re: Jeremy Homser Jeremy Homser 06/14/20 07:37PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 08:58PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/14/20 09:41PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:30PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/14/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 01:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:33PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/15/20 04:54PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/18/20 09:36PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/18/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:23PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:27PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/22/20 12:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 03:27AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 09:13PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 07/09/20 11:00PM
