Re: Bianchi Eagle - 1979?
Michael Branscombe /
I put the head back on and took the weight off and released the clutch, took the fan off to get access to the flywheel nut. I marked the flywheel to the housing, and with a wrench on it, I can see the flywheel move back and forth 1/8 inch in each direction, but it does not move and stay, it moves back to the mark as soon as pressure is released. Couple questions -
Am I just noticing play in the mechanics, or is the piston moving slightly as I try to rock it back and forth? I tried to look in the plug hole, but I can't see well enough with the head on to see if it is moving. My guess is it is just play in the mechanics, but I don't know, maybe just pessimistic.
How much pressure can I put before I bungle things up? I did loosen the flywheel nut, so - figure that much pressure is OK, but not sure. I've always just put rope in the cylinder to remove fly wheel nuts before, so - my experience is pressure enough to turn the flywheel nut off is fine, but don't know these motors.
  Bianchi Eagle - 1979?Topic by: Michael Branscombe Michael Branscombe 05/20/20 08:57PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/21/20 09:58PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:55AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 01:35AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:40PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 04:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:15PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 06:17PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:49PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 10:45PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:19PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:46PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/23/20 12:58AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/24/20 02:25PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 03:38PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 08:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/26/20 06:59PM
  Re: Bianchi Eagle - 1979?Re: Rob P Rob P 05/27/20 05:23AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/27/20 09:35PM
  Re: Bianchi Eagle - 1979?Re: Satan 666 Satan 666 05/28/20 06:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/28/20 10:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/31/20 10:22PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/02/20 03:29PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/07/20 01:41AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/07/20 11:01AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 09:54AM
  Re: Bianchi Eagle - 1979?Re: pat splat pat splat 06/08/20 10:24AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 12:47PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/08/20 10:40AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 02:31PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 07:29PM
  Re: Bianchi Eagle - 1979?Re: Jeremy Homser Jeremy Homser 06/14/20 07:37PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 08:58PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/14/20 09:41PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:30PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/14/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 01:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:33PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/15/20 04:54PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/18/20 09:36PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/18/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:23PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:27PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/22/20 12:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 03:27AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 09:13PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 07/09/20 11:00PM
