Re: Bianchi Eagle - 1979?
Michael Branscombe /
Well, I found a few manuals for similar models - and one for the motor (it is the Minarelli V1) - so, started kind of going over it. I've done a few old tractors and some 70s snowmobiles, so - not my first adventure in getting and old machine going, but my first moped.
The front tire holds air, the rear is shot. I'm holding off on purchasing anything for it, because it appears the motor, which I thought was free, seems to have a stuck piston. I put the bike on end and pulled the carb and head, and filled the cylinder with seafoam, so - we'll see if that gets it to loosen up. Other trouble is the screws/bolts that hold the housing to get at the ignition seem rusted solid, so - put some penetrating oil on them, if they don't let go - I guess I'll just drill them out.
Put oil on all the bolts, you never know what's going to get taken apart - so, I just always do that on an old machine that I'm trying to go over. The right foot rest is missing, and the front bracket that is on the frame is broken off.
No brake cables. Pulled the lights off, so I don't break them horsing the thing around, tail/brake light is missing lens.
Gas tank rusted, and had old gas. Pulled tank off bike and started juggling some old nuts and bolts to loosen up the rust.
Only had one chain, that was broken, so - would need new ones. No speedo cable.
Drained the oil and filled with fresh 30 weight.
Guess I'll have to see if the piston frees up. I've rebuilt a few motors, but never seen a stuck piston before. Cylinder seems to have light surface rust, but not terrible.
  Bianchi Eagle - 1979?Topic by: Michael Branscombe Michael Branscombe 05/20/20 08:57PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/21/20 09:58PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:55AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 01:35AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 12:40PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 04:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:15PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 06:17PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 06:49PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/22/20 10:45PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:19PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/22/20 09:46PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 05/23/20 12:58AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/24/20 02:25PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 03:38PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/25/20 08:55PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/26/20 06:59PM
  Re: Bianchi Eagle - 1979?Re: Rob P Rob P 05/27/20 05:23AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/27/20 09:35PM
  Re: Bianchi Eagle - 1979?Re: Satan 666 Satan 666 05/28/20 06:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/28/20 10:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 05/31/20 10:22PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/02/20 03:29PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/07/20 01:41AM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/07/20 11:01AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 09:54AM
  Re: Bianchi Eagle - 1979?Re: pat splat pat splat 06/08/20 10:24AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/08/20 12:47PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/08/20 10:40AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 02:31PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 07:29PM
  Re: Bianchi Eagle - 1979?Re: Jeremy Homser Jeremy Homser 06/14/20 07:37PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/14/20 08:58PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/14/20 09:41PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:30PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/14/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 01:16AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/15/20 03:33PM
  Re: Bianchi Eagle - 1979?Re: P D P D 06/15/20 04:54PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/18/20 09:36PM
  Re: Bianchi Eagle - 1979?Re: Trent Anderson Trent Anderson 06/18/20 10:21PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:23PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/19/20 12:27PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/22/20 12:29AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 03:27AM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 06/30/20 09:13PM
  Re: Bianchi Eagle - 1979?Re: Michael Branscombe Michael Branscombe 07/09/20 11:00PM
