rear brake cable help
I put a bernardi swing arm on my magnum and all of a sudden i cant get any rear brake cable to fit. Am i doing something wildly wrong? i measured and measured , it goes slack if i turn the handlebars to the left and it tigthens up if i turn the bars to the right. im so stuck on how to adjust this., ive gone through so many cables and need some guidance.
Re: rear brake cable help
Post a pic. Sounds like you forgot the barrel adjuster on the hub.
i figured it out, i just need a stronger spring
