Re: Cub Oil strainer
Born to be WillD /
kickstart shaft is a split the cases deal. it's really the only weakpoint i can think of on the cubs, the dreaded broken kickstart shaft.
I will say though you can get by quite well without it, i pushstarted my cub for years without ever relying on the kickstart at all.
ANyhow, the oil strainer filter screen goes in the slot under the clutch on the bottom of the clutch side, i found a pic from the manual:
