ive used blue medium lock tite and few hours later ill go to ride it so I check on the New crush exhaust gasket and it turned easy like it's loosen up just sitting there? Any suggestions to keep exhaust gasket sealed on a35 ? Thanks
Star or stop washer tighten when hot do not over torque. The problem is universal.
Crush gaskets do just that when hot they collapse.the simple metal ones are the best they maintain the thickness and are less likely to crush and leave slack. When you do a crush gasket you install the gasket let the bike run a few minutes till hot Then retighten ride a day check and retighten.
