Re: Puch/ Rear Tail light help!
Mike Boyd /
The tail light ground runs off the fender/frame which is not the best situation. I usually run a ground wire from the engine block down under the fender (zip tied to the brake light cable sheath) and wire the ground that way just to prevent a poor ground causing blown bulbs as well.
