Re: Motobecane Front Wheel Grinding When Axle Nuts Tightened
Trent Anderson /
The rounded nut that presses against the ball bearings is double nutted at some point, usually right at the nut or after a spacer. If it's not double nutted or the double nut isn't tightened properly, wouldn't tightening the axle nut tighten all that up, possibly improperly, causing that issue?
Make sure you've greased those bearings.
If the bearings are pressed in instead of loose, not sure what to tell you.
