Re: Motobecane Front Wheel Grinding When Axle Nuts Tightened
Francis Davis /
Since I took this video I added a washer behind the bushing on the brake side, seemed to marginally improve the situation but same issue persisted. There is now a little bit of a gap between the brake carrier and the hub, not sure if adding more space would help anything. It looks like the brake carrier is grinding against the bushing for some reason.
