Re: '77 Puch Maxi 1.5
Jay Rivett /
I would just get down and dirty with it. Remove the carb and the pipe, make sure they are both clear... drain what fluid might be in the engine and replace it with some fresh 0w engine oil. Get yourself a new spark plug as well. Once your tank is cleaned up you should be good to go.
