Re: Smily Can't make it up hills...
Stephen Keller /
Don't think this would slow you down, but 20:1 is crazy oil rich, and will carbon up your exhaust port and pipe quick. Anywhere from 32:1 to 50:1 is fine. If I remember right this is a single speed moped, and they just don't have the power for hills, especially if you are on the heavier side. Repack wheel bearings, and be sure tires are properly inflated. Remember, this is a comfortable bicycle, NOT a slow motorcycle. Fix your air leak before messing with jetting.
  Smily Can't make it up hills...Topic by: Pea-Jae Stasuk Pea-Jae Stasuk 05/07/20 11:53AM
  Re: Smily Can't make it up hills...Re: Cpt. F. Cpt. F. 05/07/20 12:09PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/07/20 12:17PM
  Re: Smily Can't make it up hills...Re: Dan (high idle) Conway Dan (high idle) Conway 05/07/20 09:36PM
  Re: Smily Can't make it up hills...Re: Cpt. F. Cpt. F. 05/08/20 12:29AM
  Re: Smily Can't make it up hills...Re: Pushrod Fifty Pushrod Fifty 05/07/20 12:30PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/07/20 01:18PM
  Re: Smily Can't make it up hills...Re: Stephen Keller Stephen Keller 05/07/20 02:20PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/07/20 04:37PM
  Re: Smily Can't make it up hills...Re: Jeremy Homser Jeremy Homser 05/07/20 09:03PM
  Re: Smily Can't make it up hills...Re: Pushrod Fifty Pushrod Fifty 05/07/20 09:22PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/08/20 04:36PM
  Re: Smily Can't make it up hills...Re: Bob Naske Bob Naske 05/08/20 07:02PM
  Re: Smily Can't make it up hills...Re: Pushrod Fifty Pushrod Fifty 05/08/20 08:22PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/08/20 09:56PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/08/20 10:13PM
  Re: Smily Can't make it up hills...Re: Tim Doll Tim Doll 05/09/20 09:15AM
  Re: Smily Can't make it up hills...Re: Bob Naske Bob Naske 05/09/20 12:18PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/09/20 05:34PM
  Re: Smily Can't make it up hills...Re: Rich Condor Rich Condor 05/09/20 03:15PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/09/20 06:26PM
  Re: Smily Can't make it up hills...Re: Pea-Jae Stasuk Pea-Jae Stasuk 05/09/20 06:28PM
