pedal shaft seal
If a pedal shaft seal is damaged, will it just leak or will it interfere with compression and run terrible. Its probably irrelevant but I am referring to a morini engine.
I also have leaks on the rubber from the throttle cable to the carb and a damaged o- ring on the choke so its not easy to troubleshoot if the pedal seal is a problem yet too.
Re: pedal shaft seal
Bump
Pedal seal is not an `inleakage of air' problem unless you have bad crankshaft seals.
No. The crankcase isn't connected. You'll leak oil tho...
Depending on the bike you can change it without splitting the cases
