pedal shaft seal
kenny s /
If a pedal shaft seal is damaged, will it just leak or will it interfere with compression and run terrible. Its probably irrelevant but I am referring to a morini engine.
I also have leaks on the rubber from the throttle cable to the carb and a damaged o- ring on the choke so its not easy to troubleshoot if the pedal seal is a problem yet too.
