Re: Puch za50 Tran fluid fill
Nile Muti /
> Overpriced Parts Wrote:
> It’s a separate area, the plug will not go through into the tranny hole
> it’s too small,
> Use a self tapping screw into the degraded plug after you drill a pilot
> hole, pull/‘remove the plug best you can, Do not use junk type F fluid
> that was obsolete 30 years ago, you need to use synthetic auto motor oil
> 0W 20 5w20-30W and overfill it maybe an ounce after starts coming out of
> the hole.
Facepalm, I just got a Maxi that has a grinding metal on metal sound, and i believe its the crank shaft bearing that is shot. So I drained out the oil to see what the oil looks like, seriously, only 3 tablespoons of oil drained out, and I filled it back up with Type F trans fluid like the Puch manual said to. So synthetic 5w20 or 5w30 is the way to go? Damn, Im always late to the party on shit like this. Will drain all 3 puchs right away and refill with synthetic, thanks overpriced
