Re: Puch za50 Tran fluid fill
Probably Fred /
It’s a separate area, the plug will not go through into the tranny hole it’s too small,
Use a self tapping screw into the degraded plug after you drill a pilot hole, pull/‘remove the plug best you can, Do not use junk type F fluid that was obsolete 30 years ago, you need to use synthetic auto motor oil 0W 20 5w20-30W and overfill it maybe an ounce after starts coming out of the hole.
