Re: Minarelli v1 piston issues
baird co /
> Rick T Wrote:
> Really? I've been pointing the arrow up every time
"...every time..." So, how many pistons have you had to replace?
If you don't know which way a piston goes, an easy way to figure it out is to make two dots on top of the piston where the ring pins are, then put the piston in the cylinder (without the rings) and see if your dots cross any of the ports, including the transfers. If they do, turn the piston around and try again.
You dont want the ring pins crossing a port, because your ring will go inside and break.
Or you could just look it up...
From polini FAQs:
I’M FITTING MY NEW PISTON. WHAT’S THE DIRECTION OF THE ARROW I FIND ON THE TOP OF THE PISTON?
The arrow must be directed towards the exhaust port.
